跳转到主内容
三星旗舰手机的大号版本。发布于2018年3月。
Separate glass from LCD display and digitizer
How do would one replace just the glass on the Galaxy s9+ since the LCD display and the digitizer still work perfectly fine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
1个答案
最有帮助的答案
You would separate the glass from the LCD with heat and wire, or something very small in width like a playing card. Heat up the screen and insert wire or card between the class and the lcd. An LCD is like an egg shell, so it is very easy to break will trying to remove the glass. If you successfully remove the glass, you need to clean the LCD to remove all the LOCA (glue). After you clean the LCD, you need to put LOCA on the LCD and then put the glass over the LCD and position it right. After you have it positioned properly and all air bubbles are out, you need to cure the LOCA with a UV light. After that you just re-assemble the phone.
This process is very difficult and I suck at keeping the LCD from breaking.
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
Andrew Baltazar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,917
