跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6S Replacement Screen and Battery Not Working
I replaced the battery and screen on an iPhone 6S for a friend. She ordered the parts off of eBay. She said that even though the screen was cracked, the LCD still worked. I first disconnected the battery and swapped it out. When I went to turn it back on, it made the noise like it recognized the charger, but the screen was totally black.
When I swapped to the new screen, it had the same problem. The battery says that it has the same voltage as the OEM battery, but it was supposed to be 2200 mAh, as opposed to the standard 1715. I checked the connectors and they don’t appear to be damaged. Also, it is still able to receive texts. Every once in a while the phone screen will flash when it is turned on. I have changed a lot of screens in the past and have never seen this issue. Does anyone know what it may be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Have you tried putting your old battery back in?
完成的
I have tried the old battery. It had the same problem.
完成的
Was the old screen displaying an image before you replace the battery?
完成的
She said it was, but I never saw it working.
完成的
添加一条评论
2个答案
已选择的解决方案
When you replaced the battery, did you remove the screen to do so? And was the battery disconnected before and during the removal and installation of the screen?
Leaving a battery connected while you fiddle around with the screen connectors can lead to blown backlight filters, which is exactly what your symptoms sound like. To be certain, shine a bright light on the screen immediately after connecting the phone to a charger or iTunes enabled computer. If you can see a dim image, then the backlight filter is blown.
这个答案有帮助吗?
得分 3
1条评论:
I did remove the screen before replacing the battery, but I did disconnect the battery first. Is there something else that can cause blown backlight filters? I thought it might be the backlight but I wasn't sure how that would happen.
完成的
添加一条评论
This might just be either a short in VCC_MAIN or a bad battery. Try an Apple OEM battery and if that doesn’t work, then it probably has board level damage.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert Black 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 91
