跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Can I install older iOS's on my iPhone?
I would like to know if is possible to install older iOS on iPhone 4S.
This thing is important because I’ve got an iPhone 4S with 9.3.5 iOS and I noticed that this iOS is really slow, so I would like to downgrade to iOS 7.0 but I noticed that this is not possible because Apple didn’t sign iOS 7.0 or 7.0.x.
So, what is the solution? If Apple didn’t sign an iOS, but if I’ve the file of iOS 7.0.x is possible with another software downgrade actual iOS to iOS 7.0.x?
Thank you in advance for reply.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If Apple isn't signing the OS it’s impossible to downgrade to a non signed iOS. There isn’t a good way around this, either.
Update (11/26/2018)
So that’s what this is all about?
Exporting IPA files (of Apps) from iOS 9.3.5 of iPhone 4S
Build a NEW iPhone
Restore device with iOS 4.0
这个答案有帮助吗?
得分 1
1条评论:
So there aren't software that can be used with jailbreak and that can downgrade iOS 9.3.5 to iOS 7? Because with iOS 7 is possible using whatsapp, but with iOS 6.1.3 (that is really fast and good for iPhone 4S) not, isn't possible. So, or I downgrade iPhone 4S to iOS 7, or I install whatsapp on iOS 6.1.3, so, what can I do? Whatsapp can't be installed on iOS 6.1.3, or there is a solution about this?
完成的
添加一条评论
添加你的答案
Patrizio Masini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 329
