跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
Water damage - Screen brightness turns on and off
Hey folks. I had accidentally spilt water onto my MacBook Air and had immediately closed it. After 24 hours of drying it I have found the system is able to be charged and everything to be working.
I had then closed it for an additional 24 hours and realised that the screen would continuously flicker from full brightness to 1% brightness (can't see anything at all). This brightness would last for Iess then 10 seconds before blacking out, it would require me to press something on the keyboard for the screen to activate. I have opened the bottom of the system and so far have not seen any sort of corrosion on the logic board. Is there anyone that can direct me to the whats causing the brightness to flicker and if its possible I can repair it myself.
EDIT: screen does not die if brightness is low
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The logic board has stuff on the back side which you can’t see. This is the side that would have gotten wet!
You’ll need to remove the logic board and inspect it I’m suspecting the Buck controller might have some corrosion damage (Blue Chip)
这个答案有帮助吗?
得分 2
2条评论:
Hi Dan!
Thanks for the answer. I will have a look, just a little update, after leaving my computer on continuously my computer is now working normally with no screen flickers at all. Should I take it for diagnosis with a third party dealer?
完成的
Sounds like you still had moisture inside. I would take the logic board out as you might need to do a bit of cleaning.
I don't think you need a dealer unless you're all thumbs or just don't want to do it.
完成的
添加一条评论
添加你的答案
Chino Lagdameo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 111
