跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
Replaced logic board and still having the same no backlight issue.
Replaced the logic board in the display with no difference. Pretty sure I can rule out logic board failure. No backlight but the display still has a picture with flashlight head closely. And the camera, usb, and ethernet still work the same. The charging for the older macs still works as well. Would it be the power supply not applying power to the backlight or the LCD? I have had stints of perfect operation in short bursts regardless of which logic board, but only after lots of messing about with plugging power in and removing it. I really don’t have another resource for information like this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Is it the controller board on the LCD itself?
完成的
添加一条评论
1个答案
最有帮助的答案
The LCDs are quite common to fail on these unfortunately, so it’s likely the LCD controller board.
In cases where we have the same symptoms, we’ve found it to either be main logic board or LCD panel.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
huntertrainboy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 72
