跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
What are the plastics used for the LCD backlight diffuser?
I would like to know what are the plastics used to make each layer of the LCD backlight diffuser. I counted 6 in total, but I don’t know what they are. Any help is appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Usually you can find diffusers, Fresnel lenses, and polarizing films. Fresnel lenses are sometimes used in the back-side for amplifying the back light, polarizing films are needed for LCD’s
Edit, what materials are they made from:
Polarizing film is made by dyeing film (mainly polyvinyl alcohol (PVA)) or by iodine being adsorbed onto its surface, then stretching and orientating it. This gives the film polarization characteristics that allow only light with a certain oscillation direction to pass through it.
The Fresnel and diffusers are usually made of a PVC film
这个答案有帮助吗?
得分 2
3条评论:
Would you by any chance know what material is used to make the diffusers and the polarizing films?
完成的
完成的
Thank you for the help! Apple says that no PVC is used to make the iPhones, so I researched it a little more to see what else I could find. This website (http://informationdisplay.org/id-archive...) confirms that the Polarizing film is made out of PVA with a layer of TAC encapsulating it. It also says that the prism sheets are made out of PET or PC film and the diffusers out of PET with resin beads on top.
完成的
添加一条评论
添加你的答案
Luiza Guidi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 432
