跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
How do I use a smartphone digitzer with a computer (arduino/RPi/PC)
First, I know this is not the appropriate place to ask the question but I believe people here can help and I don’t want to miss out on getting in touch with them.
I need to read data from a smartphone/tablet digitizer for my project. (it will be then process with Arduino/RPi or similar computer)
(please direct me, if you know someone who can help)
Thank You.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It’ll certainly be an interesting project but I don’t think it will be easily accomplished. The control IC’s are embedded in the screen assembly though so that helps a bit. The touch screen is not resistive (as discussed in Isaac’s the link) but capacitive. The interface is also comprised of the pins below:
Anything with “Touch” in the netname will be relevant to your project.
这个答案有帮助吗?
得分 3
1条评论:
Thank you, Minho!
完成的
添加一条评论
This might help: http://forum.arduino.cc/index.php?topic=...
这个答案有帮助吗?
得分 2
2条评论:
Thank You, Issac!
完成的
You're welcome
完成的
添加一条评论
添加你的答案
Sandeep 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 299
