跳转到主内容
加入维修社区 - 创建账户
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
Why aren't my engine fans not coming on?
I have a 1994 Toyota Camry 4cyl 2.2l engine. I'm having a problem with my radiator cooling fans not coming on when car is hot. Could anyone suggest a solution or send a diagram of how to wire my engine cooling fans? Not sure what do.I don't know where to start to troubleshoot the problem. Someone help me?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here’s a link that may be of some help. Scroll to the 2nd post in the link to view the image showing the engine coolant sensors.
There are two coolant sensors. One for the temperature gauge in the dashboard instrument cluster and the other is for the ECM (Engine Control Module). This is the one that is used by the ECM to know when to turn on/off the radiator fan.
The replacement part is available online. Just search for 1994 Toyota Camry 2.2L ECM coolant temperature sensor to get results for suppliers of the part.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Tonya Hudson (Boomcartbasket) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 810
