I have broken the on/off switch on my DMC-FZ70 can it be fix
The on/off switch on my camera is broken can it be fix
These switches are built into the control unit and proper fix calls for the entire control unit to be replaced. See guide:
Panasonic DMC-FZ70 Operation Unit Replacement
If you’ve just broken off the tab for the switch and there’s still something to grab onto, you can glue something onto the ring of the on/off switch for easier actuation as a quick fix. If there’s nothing left of the on/off switch the replacement of this portion of the top panel is your option.
这个答案有帮助吗?
This switch is part of a control unit that can be purchased and is reasonably easy to fit. A video is available.
这个答案有帮助吗?
The video is online along with other repair tips egg.
You can. Search the part online and get one. Search how to fix it in online. You can get it. I saw somewhere for the same.
这个答案有帮助吗?
You might try putting in the model number and your zip code on their service center locator, found here: http://www.servicebench.com/templates/ge... unfortunately I can't seem to find parts for that camera, I've always worried about what might happen if I broke that part off on mine, I think I'd 3d print one if my own ever breaks off. If I find anything else, I'll add it to this post.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 15
总计 776
