跳转到主内容
The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
59 个问题 查看全部
My phone only charges when turned off
Hello,
Up until recently my phone has been working fine, charging normally and my usb stick worked in it (it has usb one end and mini-usb the other, it used to work perfectly for transferring data from computer to phone etc) without issue. Recently the usb stick stopped showing up when I put it in, and so I thought maybe there was a build up of lint in the charging port, I tried to clean it out but all I could find to do it was a little pin (metal). Since then whenever I charge my phone nothing happens (I’ve tried various working chargers and cables) until I turn my phone off and then later back on its obvious its charged. I’ve looked a fair bit online and I think I have to replace the charging port, I just wanted to check with you guys before I try and open my phone, something I’m quite a beginner at.
It's worth noting that my girlfriend has a samsung too, and my usb stick, and all the chargers and cables work in her phone.
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I think you are headed in the right direction. However, let’s try a hard reset to rule out any software issues.
如何硬格式化 恢复出厂设置 Samsung Galaxy A5
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
therealtommyleek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 875
