跳转到主内容
The RCA Voyager Pro tablet is a perfect entry into a world of wonder and entertainment. Running on Android’s Lollipop, the Voyager Pro is sure to excite and entertain.
47 个问题 查看全部
The settings aren't loading at all, and eventually tell me to close em
So the other night I tried to update one of my apps, but for some reason it wouldn’t let me. I decided to restart the tablet, but then when I turned it back on I’ve been having problems ever since, and I have no clue why. The app store closes automatically and it doesn’t even give me a message, and Google Chrome tends to do the same thing, too. I would go into settings to try and see what was going on, but the settings would never load anything, and after a while it would just tell me that it isn’t responding. Every time I restart the tablet, I still have the same problems. I tried safe mode, I still have the same problems. I leave it on while unplugged until the battery goes out, turn it back on, I still have the same problems. Sometimes the tablet will also freeze for a bit, and then go to the “Swipe up to unlock” screen. I happen to have AVG Anti-Virus installed, and I scanned the tablet for viruses and got nothing, so I’m certain that this isn’t some virus.
So yeah… does anyone know what’s going on here?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Let’s do a hard reset of your tablet to eliminate a software problem. Hard resetting your tablet will erase all of it’s data, so proceed at your own risk!
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Step 6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished. Congratulations, you have successfully reset your RCA 7 Voyager tablet.
These instructions are to hard reset a similar RCA tablet, hopefully they work on your tablet.
Credit - cannot reset my tablet to factory default
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Final Fighter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 294
