跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
LCD bleeding purple to black
Hi again guys,
I have an iphone 5s that I have an issue with and I would like some opinions on…
The phone powers on etc and the owner reports that everything functions as it should… However, the screen has lines on the right hand side that cover about 0.5-1cm of the screen… the phone ocasionally displays the setup menu and/or turns purple and then fades to black from the outside in! I shall try reseating the connectors but is this just a replacement screen job or could there be board issues…?
also, the phone seems to power off once the screen has faded as you can see a spinning circle…
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
just an update, i have removed the screen (but not reinstalled it yet...) apple, who previously replaced the screen, did 2 of the screws up so tight that I couldn’t undo them!! Had to swivel the brackets out of the way! Just noticed some purple “ink” kinda stuff next to the top left screw of the screen cables bracket... is this a bad sign?
完成的
添加一条评论
1个答案
已选择的解决方案
The screen is obviously damaged so it needs to be replaced. Only then will you know if there is further damage to the logic board.
这个答案有帮助吗?
得分 3
1条评论:
Perfect thanks man
完成的
添加一条评论
添加你的答案
Ed Beckett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,506
