跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Boot loop when any front camera connected
Hi, ive recently repaired an iphone 7+, and after doing a battery and screen replacement on the device it gets stuck on a boot loop. Easy fix i think so I disconnect the front camera as i know there can sometimes be dodgy proximity sensors on screens and it boots up.
So i think its problem solved and connect a working but cracked screen from a previous repair ( Have repaired over a hundred phones for a little bit of side income) and the same issue occurs. So at this point the new battery starts playing up so I change that for a spare and its charging now.
I’ve tried different screens and camera assembly and it refuses to boot when the front camera is connected most times now but sometimes boots and then the camera and earpiece don’t work.
Any idea on what the issue could be?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
back up ur iPhone replace the camera restore the phone its should solve the issue,
the restore from backup
这个答案有帮助吗?
得分 0
1条评论:
The OP has already tried different cameras.
完成的
添加一条评论
Hi Daniel, here is Zoltan your friend :D
I get this issue 3 times, and now I think the problem is related to the Audio IC.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
daniel hegyaljai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 602
