跳转到主内容
Samsung's robotic vacuum featuring Wi-Fi connectivity. Model number: VR2AM7070WS/AA.
8 个问题 查看全部
PowerBot R7040 Runs with disengaged powerbrush
my powerbot recently started to show this glitch where it actually runs pretending like it is cleaning but without actually vacuuming anything.(no powerbrush running) If i hit pause and then start again it starts and runs as expected. I’m not sure how often does this happen since it cleans mostly when I’m not home. I was only able to catch this on weekend.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
same here, I just unplugged mine, tired it riding around dirty and not cleaning.
完成的
添加一条评论
6个答案
最有帮助的答案
Mine begin doing the same thing. It was also making a very loud noise like gears and grinding. I have taken the unit apart and determined the same answer as Jameso84. I was able to find that the belt inside the unit was simply a 3-D printer timing belt P/N 2M-136-6. This signifies that the belt is 136 mm in length, 6 mm wide, and has coggs spaced 2 mm apart. I have tried replacing the belt, and it worked for a while but began doing the same thing. I believe since it was grinding long enough, the teeth on the motor side have worn down to the point where it won’t engage the belt properly. I have now ordered the entire power brush motor assembly P/N DJ97-02486B. I have yet to receive it and install it but this should fix the problem.
这个答案有帮助吗?
得分 3
2条评论:
Where did you got the new belt? I can't find a place where I could order it.
完成的
Amazon. Came from China.
完成的
添加一条评论
Mine did the same thing, and progressively got worse…I found that the small belt in the power brush drive has missing sections and eventually never moved again. It’s pretty difficult to get to.
这个答案有帮助吗?
得分 2
1条评论:
are there replacement belts available for it?
完成的
添加一条评论
I’m also looking for a belt. Incredibly difficult to find!
这个答案有帮助吗?
得分 0
添加一条评论
Has anyone figured out where to get this belt? I would also like to find the two gears as well if possible. Ordering the entire assembly for $90 + shipping is one, expensive and two, a waste of a perfectly good motor.
这个答案有帮助吗?
得分 0
添加一条评论
I just ordered the 2M-136-6 (GT2-136mm) belt from Amazon for $7.99: https://www.amazon.com/gp/product/B07VZ5... This is to get me up and running.
Since I was thinking about it I ordered 3 spares from China, $0.40 each plus $4.00 shipping: https://www.robotdigg.com/product/805/13...
Be sure to specify the 136-2gt-6 belt (136mm long, 2mm tooth spacing, 6mm wide), or whatever size you need.
这个答案有帮助吗?
得分 0
添加一条评论
samsung should repair free of charge, this is a poor project
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrey Smirnov 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 12
总计 1,406
