跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
问题已关闭
Hard drive brands
Is a Hitachi hard drive a good drive to use in a 30GB video iPod?
ADMIN EDIT: Here is the entire context for the question. For those of you who are answering, please look at the context of the question to best answer: first, second, third, forth, fifth, sixth, seventh, eighth, ninth.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Tristan, looking contextually at your posts, you have some unique issues with your iPod. Rather than creating a new question every time there is a change, please just update one question with the progress. This context is very important for those Answering to adequately diagnose the problem. It will aid in supplying the most accurate answers for you. Thanks!
完成的
添加一条评论
3个答案
最有帮助的答案
The Hitachi drives are good BUT if your iPod has a Toshiba drive, you will need a new hard drive cable (select the Hitachi option). Hitachi drives have a different connector than the Toshiba drives, that necessitate a different cable.
这个答案有帮助吗?
得分 2
添加一条评论
Why not use one from iFixit? This one is actually Toshiba, any place is good though, hitachi should be fine, as long as it's a reputable vendor and is the right type.
这个答案有帮助吗?
得分 0
1条评论:
Price difference.
完成的
添加一条评论
yes Hitachi is a reputable hard drive maker (did you know? they purchased IBM hard drive's division almost 10 years ago. and FWIW IBM pioneered the original hard drive mechanism)
these days there's only a handful of hard drive makers anyhow (about 5 of them, Toshiba is one of the others) - I'd say any brand for your iPod is probably fine. as rab777hp said, just buy the correct type from a reputable vendor.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 1,521
