跳转到主内容
Repair information for the Samsung Galaxy J3 (2016) Duos. Model Number: SM-J320F/DS
20 个问题 查看全部
What is wrong with the screen of my phone? And what do I need for it?
It fell from my hands to the floor as the screen was facing downwards. Then its screen went complete black. But it still accepts finger touches. Like I can unlock my phone (it has a slide lock), answer a call etc. Because I approximately know where to touch and slide to perform those operations. Also, there’s a little cracked scratch line on the screen, and the whole screen looks like it’s kind of wet when I put it under light. Now I want to buy the screen needed online. But I’m a little bit confused what exactly is needed, and so I don’t want to pay for a wrong phone part. So I decided to ask for help to figure it out. I did a little bit of research and this is what I found:
https://www.ebay.com/itm/Pantalla-Para-S...
Is that what I really need for my phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
That part should work fine for you. The LCD and the digitizer are fused together so you can’t just replace one part without all the skills and tools necessary. Before replacing the screen, make sure the display cable is tightly connected and not partially disconnected as that may be why you have no display.
TL;DR: Yep, thats the right part. Make sure the existing display is tightly connected before replacing the full screen, just in case.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
John Doe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 84
