跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Black screen but backlight works
So the first time this happened was yesterday, and I waited for about 1 hour and the computer worked properly until 7-8 hours ago. In the time while it was working, I have closed and opened the lid multiple times but when I open it the last time (7-8 hours ago) it was the same problem and I waited like 5 hours but it didn’t fix itself.
The problem is the backlight is turned on and the Apple logo on the back is lighting. I can adjust the brigthness and the backlight will change colors from black to nothing. (The outside of the surface and the screen is distiunguishible, the screen is like a black light.) The backlight of keys work properly.
I connected my Macbook to an external monitor via HDMI and the external screen shows Mojave background, and when I enter my password and press enter it shows the background of my 1.st desktop, not the background of the external monitor. When logging in i didnt see my icon and password bar, the external screen just shows the background. When I’m in the computer, the mouse is visible in the external monitor but i cant click, click and drag, right click and there is no top bar and bottom bar. I can just move my mouse.
I tried the Internet Recovery (Cmd+D if im not mistaken) and it showed in the external monitor the world icon and i entered my wifi there and so on. After a while it said your computer has no problems, and i tried to get it to safe boot. I can’t see anything on safe boot, just a gray screen, exactly like what happens when I normal boot.
I think that the monitor connector might got off or something like that but i don’t want to open my computer and try to fix stuff without being sure of the actual problem. Also a friend of mine said take off the battery and put it back in, it might work. I’m not sure about what to do…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
As you can see the default background on the external we know the GPU is working so the connection of the internal might need to be checked.
But, lets review one more thing here as by default your external display would be in mirror mode not second screen mode, did you alter it? Thats, why you can’t see your icons or the background you set for your internal display.
So what we need to do is try resetting the SMC following this Apple T/N How to reset the System Management Controller (SMC) on your Mac. Removing the battery as your friend suggested would end up doing the same thing. If that fails you’ll need to go into Safe mode so you can reset the display setting.
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 2
1条评论:
I did a SMC reset but i think it didn’t do anything. I connected 2 external monitors, and for 10 seconds I think one of the monitor cables were not totally in so my MacBook showed my screen but when I took the DisplayPort cable out, my screen went black again. Also when I logged in as a guest, I could see the top bar and I could use the Search Bar, and I could click/right click, but when I got back to my account, i coundn’t do any of these. Btw in guest mode my MacBook was still black.
完成的
添加一条评论
添加你的答案
Ahmet Karabey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,513
