跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
How to restore ios when itunes doesn't work
Can someone please help. I dropped my iphone 7 plus the other day and it worked fine then i woke up the next to a itune symbol saying restore with itunes (recovery mode).
I have tried putting the phone in recovery mode and in dfu mode. Itune says its preparing my phone for restore but it just hangs there with that phrase. Could this be because the screens damaged ..pic is included in post. Im running the latest itunes on mojave macos
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The drop probably damaged the logic board or one of the major modular components in your phone. I don’t believe this is a software issue.
You could try to open your phone, disconnect the battery and then proceed to disconnect pretty much everything (screen, cameras. sensors, buttons) except the Lightning port. Then reconnect the Lightning Port and connect it to your iTunes enabled computer. If it still boots to recovery mode and fails during recovery, then the odds are you have a logic board issue. This will only work if you have no passcode and have previously “trusted” your computer.
这个答案有帮助吗?
得分 3
2条评论:
@refectio okay i will try this..so just replacing the screen most likely wont fix this...are any of the parts your refering to take off soldered on to the board
完成的
No these are all done with connectors.
完成的
添加一条评论
Fix the phone, then restore.
这个答案有帮助吗?
得分 2
5条评论:
How do i fix if i dont know whats wrong
完成的
@mayer Where should the OP start? What should the OP test for?
完成的
What is a op test
完成的
I think @refectio is better suited on how to approach a repair on it.
完成的
OP stands for Original Poster...aka you.
完成的
添加一条评论
添加你的答案
PopKulture215 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 69
