跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Touch id on iPhone 6s won't work after transferring home button over?
Have a question, Had an iphone 6s where i replaced the screen and transferred over the original touch id, home button as I know you can't use a new one. I've done this many times, but this time the touch id won't work after put back together. It doesn't give any error at all. Just when you try to add new finger print, it acts like you don't have your finger on the home button... No errors. It just won't prompt you to scan your finger and can't get it to work. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
It’s either a bad home button or a bad home button cable by the sounds of it.
完成的
Thanks. I've replaced the screen twice in this phone, so maybe that's possible. So, there's no way to fix this cause this is still an only apple fix?? It's a backup phone, but I sure would like to get the touch id back. This sucks if apple it still the only one to fix this. Is it weird that there's no error?
完成的
添加一条评论
2个答案
@jason_b Well, the fact that your iPhone is giving you no errors is a red flag that either the home button or it's cable is damaged. I think you're going to have to make the sacrifice here and just buy a new home button assembly. If Touch ID still refuses to work after a new home button assembly then we have a bigger problem here, a board level issue.
iPhone 6s Home Button Assembly
iPhone 6s and 6s Plus Home Button Gasket
iPhone6s Home键组件更换
iPhone 6s Home Button Assembly图片
产品
$14.99
iPhone 6s and 6s Plus Home Button Gasket图片
产品
$5.99
这个答案有帮助吗?
得分 0
2条评论:
Thank you for the reply!!! But, I thought you can't use a new home button with touch id, and only way to get it to work is to have apple do it to record the ss to the home button? Is this not the case anymore?? We can do it ourselves and get it to work??
完成的
@jason_b the reason why I said "you're going to have to make the sacrifice here" is exactly that reason there. Nobody other than Apple can "pair" a new home button to an existing device and have Touch ID work. You don't have much of a choice here.
完成的
添加一条评论
Check out this thread for some hints:
Touch ID not working after screen replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 364
