Sanyo tv with dvd combo
I have no color on t.v. but will have color when watching an dvd, I have an t.v. with dvd combo
Update (11/16/2018)
Model # DP26670
Cable
HMD2
Will have color when looking at dvd
Hi @capann60z ,
As you have said that there is colour when viewing DVDs you need to prove whether the problem is with the cable box (what is the make and model number?) or whether it is a HDMI cable or a TV HDMI problem.
Have you tried a different HDMI cable between the cable box and the TV?
Can you connect the cable box to the TV’s component video input or the TV’s composite video input to prove whether the problem is with the cable box or the TV?
Alternatively can you connect the cable box via a HDMI connection to another TV to prove the problem is with the cable box or the TV.
Here’s an image which shows where to connect the cable box to the available alternative TV inputs (if it has suitable outputs and you have the necessary cables). Remember that you have to select the different input on the TV once you have connected it up.
(click on image to enlarge for better viewing).
The red box shows a component video + audio connection. This requires a 3 wire cable (red = Pr, blue =Pb, green = Y for video and a 2 wire red and white cable for the audio L and R)
The green box shows a composite video connection + audio connection. This requires a 3 wire cable only (yellow = video, red and white for audio L and R)
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 290
1条评论
Hi @capann60z ,
What is the model number of the TV?
What is the source of the TV signal, antenna, cable box etc?
What type of input is the TV signal connected to on the Sanyo TV, co-ax, HDMI, AV etc?
If the signal source is a "box" of some description, can you see if it works OK when connected to another TV or can you try connecting it to a different input type on the Sanyo TV to see if it works OK?
What else have you checked?
由 jayeff 完成的
