跳转到主内容
LCD assembly for late 2010 fits early 2015?
Friend brought an early 13” 2015 Macbook Air to me. Dark screen but the image is there if I shine a flashlight to it. I have in my parts bin LCD for late 2010. Will this work as a replacement for the newer model? I’d like to try it before declaring it to be a ligicboard issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
So why do you think replacing the screen will make a difference?
If you're sure you see an image using the flashlight then you know the screen and the LVDS cable its self is less likely to be the issue.
So what could be the issue then? You’ll need to inspect the logic board LVDS connector to see if the connections are good (often times corroded). Then, you’ll need to test the fuse link to see if its still good as well as the backlight logic.
这个答案有帮助吗?
得分 2
1条评论:
I’m hoping the problem is the LED array that provides backlight. I have the LCD assembly from a 2010 Mac Air to test / replace, but I don’t have a replacement logicboard for the 2015.
完成的
添加一条评论
to answer your main question, no.. unfortunately the 2010 mbp lcd will not work in a 2015 mbp..
the technology is different..
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bernie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 67
