跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Audio and Selfie Camera Not working
I am looking to purchase this iPhone for 110 dollars, because I believe, per the description, all that should need to be fixed is replace the screen and the front proximity sensor, correct? Please see the device description below.
  1. The device has a cracked front glass, but there is no LCD damage to the screen underneath.
  1. During a phone call, the device's user is unable to hear the other party when holding the phone against their ear.
  1. The front camera (commonly referred to as the selfie camera) is not operational.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It could be just the front facing camera flex also known as proximity flex.
There is also a common issue with the 7 series phone that causes no audio due to having a fracture under the audio ic.
I would be careful with this purchase
这个答案有帮助吗?
得分 2
2条评论:
I have a contact that can fix the audio ic issue for 65 bucks, that was my other thought, but even so, with the 65 and 110, the 7 plus are going for anywhere between 330 and 515 on swappa right now.....do you still think it is a bad idea?? I am new to this whole buying, fixing, and selling process, so any input is much appreciated.
完成的
Hard for me to comment on pricing as im in Australia, if i convert that to AU that works out to be about 240au so i reckon that's a good buy.
完成的
添加一条评论
添加你的答案
Rachel Kelley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 140
