跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
331 个问题 查看全部
Buldge on lefthand side of screen
I’m trying to diagnose the problem before I order parts. I have a 5th generation ipod touch. The screen has popped off on the left hand side of the case. I have tried pressing it back into place with no luck. I’ve tried pressing firmly as well- it move freely put nothing clicks into place.
I’m trying to figure out if the issue is the adhesive has gone bad or if it is the plastic clip around the case?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The battery may be swelling. Swollen batteries can pop trackpads off Mac Laptops and make phone screens bulge like that.
Here is how you can open up the iPod to check if the battery is swelling.
iPod Touch 5th Generation Battery Replacement
这个答案有帮助吗?
得分 2
2条评论:
Thanks, I just got a chance to open it up and the battery is swelling.
完成的
@jlewv I knew it! Dispose of that swollen battery immediately, it’s dangerous and can combust if it keeps swelling...
完成的
添加一条评论
It can also be a slightly bent case. The case can bend out of shape from pressure in pockets or being dropped. If that is the problem, it can often be fixed by being placed under weight (car battery, large water jug, etc.). You can also get a new frame. (Though I’d check on the battery first, as Aaron suggested.)
这个答案有帮助吗?
得分 2
1条评论:
Thanks, it was a swollen battery
完成的
添加一条评论
添加你的答案
Joshua Edwards 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 10
总计 840
