跳转到主内容
Repair guides and support for a wide range of small engines.
103 个问题 查看全部
compression release malfunction on craftsman 24HP Twin?
I have Good fuel, good spark, both intake and exhaust valves function on both cylinders (I removed the valve covers and observed them),  I have good compression on RH cylinder, no compression on LH cylinder.  Engine will not start.  Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
No compression on LH cylinder sounds like major issue with that cylinder. Cylinder leakdown test may reveal if it is losing compression past valves or piston rings or head gasket. However, most DIYers don’t have a leakdown tester.
这个答案有帮助吗?
得分 0
1条评论:
Good compression on RH cylinder. None on LH cylinder. I can get a compression tester. Question: with a 2 cylinder and good compression on one cylinder and none in the other, wouldn't it still start? Just run really ragged?
完成的
添加一条评论
添加你的答案
Harry Laclair 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 74
