跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
Blue stains on screen
Some blue stains on bottom of screen only on black color and on dark backgrounds like boot screen and others. On white backgrounds aren’t visible. Does not affect performance or tactile sensations.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It’s almost invisible, but it is
[image|1643329]
完成的
添加一条评论
2个答案
已选择的解决方案
Without giving us any context or background (was this following a drop or repair attempt?), the screen could be improperly mounted or damaged. Give us more info and we may have better guidance to offer.
这个答案有帮助吗?
得分 2
3条评论:
I didn’t drop it and also didn’t give it to repair.
完成的
This could be a sign of a bad LCD. Can you post a picture (add it to your question)?
完成的
It's pretty subtle...if the device wasn't opened up for repair and the housing isn't damaged or warped, then I would just suspect a bad LCD. Unfortunately, the only way to know for certain is to try a known-good replacement LCD.
完成的
添加一条评论
To me it looks like a pressure mark. I know you said it hasn’t been dropped/repaired, but if it is at all bent or warped it can cause it to appear. Someone may have sat on it or something like that. Outside of that, the other comments are right it’s probably a bad LCD. Are you sure the mark is new, or are you just now noticing it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jiraya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 25
总计 4,396
