跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 个问题 查看全部
Why are there dark sections of picture on TV?
I have a Vizio E60-C3. A few sections of the picture grid have become darker then the rest of the screen. I'm not sure if this is a backlight gone out or board issue. Was hoping for some advice on how to fix since the tv works fine otherwise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This appears to be a couple of bad LED strips. This set has 2 strips per row. From the picture provided, there appear to be 2 strips out on the upper right and an entire row of 2 strips out in the middle. This unit has a total of 12 strips (6 per side). You can either purchase 4 strips and replace the defective ones, or purchase the individual LEDs and replace them on the defective strips once you locate the dead ones. Note: 1 bad LED will prevent the entire strip from functioning.
Dan
这个答案有帮助吗?
得分 2
2条评论:
Okay that's what I had thought, any idea what the replacement strip is and where I can buy it? Also if there's any how-toy's for replacing defective strips? Thanks!
完成的
One example of a strip is here: https://www.ebay.com/itm/VIZIO-E60-C3-E6...
Search Ebay using the following: "Vizio E60-C3"
You can watch the video from Shop Jimmy here: https://www.youtube.com/watch?v=VP7iNYFA...
Parts can be obtained from Shopjimmy as well.
完成的
添加一条评论
添加你的答案
Daniel Marchetti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 12,815
