Water Damage and still wont load
Hey all my first post :D now i love dealing with pain phones so i took this one on a Huaweii P10. All ive been told is it got wet it worked for a while and then it turned off. What ive done so far :-
Cleaned board with 90% alcohol stuff, that solution that Ifixit recomeneds
New Battery
New Charging Baord
New Main Flex
New Screen
When i plug the charger in all that happens is the red light on the screen flashes, it does this with the battery plugged in and out also when i press Power Up + Power i get the flashing light but i press just power i get nothing. When i got the phone it had enough power to cycle vibrate as it trys to turn on so its got to be the battery not charging.
Any body have any words of wisdom for me to try or does this need to go to someone with a sonic bath :)
Many Thanks
Simon
3条评论
Did it show signs of corrosion before you cleaned it. There's possibly a short which is why it won't turn on
由 daniel 完成的
yeah there was corriosion but i cleaned it all, only part i cant get to is under the shields but still im getting the flashing red light nothing else. Guess this one is a loss.
由 Simon Gilbert 完成的
I decided to clean the board one more time last night :) dried it off with nt heat gun on low settings and left all night. Hooked it all to this morning and put it on charge now the red has gone and been replaced with a solid white light that turns off when I hold the power button
由 Simon Gilbert 完成的
