How to make sure I'm using the full battery capacity?
Hello,
I’ve recently got an official ifixit battery repacement kit for my MacBook Pro 15 retina mid 2012.
On the product page it’s written: “New battery guaranteed at capacity greater than 8250 mAh.“
I am currently struggling to keep the mAh value at 7900 when full. Which is nowhere close to the guaranteed advertised capacity.
What I’ve tried:
Resetting the SMC.
Various tries and small variations of: charging the mac to 100%, leaving it for a few more hours to charge at 100% then disconnecting the AC until the mac dies, leaving it overnight (and even in the morning for a few more hours to make sure it’s drained), charging it fully, a few more hours after it’s 100% I still kept it plugged in, then another full discharge, charging it again and using it normally.
^I’ve done this a few times with slight variations, sometimes throwing the reset SMC before the process sometimes after, after discharging it sometimes even pressing the power button once in a while to display the low battery indicator, I figured it would drain the battery faster, before setting it to drain overnight, etc. All sorts of variations of these processes.
I am currently at 27 cycles, still trying to get to that advertised >8200 mAh
I am using the mac’s system info to see the battery stats as well as a program called battery monitor, which for example indicates to me in its UI:
current charged: 100% (7896mAh) | battery capacity: 93% (7899mAh), once I’ve gotten this battery capacity number to be about 97-98% and at about 8200mAh, but the next time I charged after that it fell into about 7600mAh range and I’ve since reset a couple times and gotten to where I am now.
The hints that I got throughout this process point me to think that there is more space in the battery to hold more charge but somewhere along the line the Mac internals / the controller on the battery simply think it’s maxed out and stops charging it to its fullest, any ideas on how to fix this?
EDIT: I am also using a new & original apple magsafe 2 power adapter with this process, it’s 100% original 85W in this quest, so I don’t think it’s because of that.
1条评论
Would also like to add that between resets I’ve mostly used it normally for about one week since it’s my work machine, then resetting it in the weekend in a slightly different way than before. So I guess I’ll leave it for about two weeks or so of normal use as @danj pointed that it would need more time to calibrate itself to its max limit, and see if the limit is higher than what I started out with right after the reset. I think if after > two weeks the mAh value won’t go up by more than 100mAh (anything under that I would consider variations) it would be safe to conclude that it’s ether a measuring issue or the battery is not quite as advertised, I fail to see other meaningful explanations to this.
由 alex n 完成的
