跳转到主内容
The third-generation HTC One smartphone which was first released in March 2015. Its major revisions on the M8 design include the octa-core Snapdragon 810 processor and a 20-megapixel rear camera.
No more charging. Not even when turned off
My HTC has been working fine till i switched phone companies. Now, not only does it drain battery faster than any cable I’ve tried, the battery still drains faster than it charges even when turned off. I had my phone on the charger turned off for two days now and it only had enough energy to power on. It stayed at 27% and has never gotten back to 100 in months. Is there a way i can fix it or should i just find another phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
As a technical advise i would like to mention these steps.I do not know whether you could perform the steps alone but read.
First try hard restting the device
If the problem still the same root the device and flash a custom kernel using flashify APK or another method .
这个答案有帮助吗?
得分 1
添加一条评论
Have you tried calibrating the battery? Or changing the battery? That could be a malware or some type of issue like that, you can try replacing the battery, trying a less powerful charger and completely reboot and restore the phone.
这个答案有帮助吗?
得分 0
1条评论:
phone has been rebooted twice, cheaper to buy new phone than new battery. haven't had the battery calibrated
完成的
添加一条评论
添加你的答案
Raven R 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 160
