跳转到主内容
加入维修社区 - 创建账户
1.8 或 2 GHz G5 处理器,最高支持 2GB DDR1 系统内存
Failed cooling of power supply
Replaced old power supply. Computer ran well for about 4 hrs after closing it up then the new power supply failed due to heat buildup. Suspect lost cooling air flow. Can a fan failure be the fan only or instead be a problem with the main board’s control of the fan?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
More likely the power supply still has the original electrolytic capacitors which are faulty!
What is the Great Capacitor Plague? And here’s a bit more: The Great Capacitor Plague of the Early 21st Century
这个答案有帮助吗?
得分 1
添加一条评论
Be sure that the fan is not clogged with dust and that the fan duct is clean.
You can also try to use Macs Fan Control to try and keep temperatures down inside your iMac if you determine that the fan and fan duct are clean.
iMac G5 20" Model A1076 Fan Duct Replacement
iMac G5 20" Model A1076 Left Fan Replacement
iMac G5 20" Model A1076 Fan Duct图片
指南
难度:
简单
iMac G5 20" Model A1076 Left Fan图片
指南
难度:
中等
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Don Jeffels 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 279
