跳转到主内容
JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
83 个问题 查看全部
Only one side works when playing music I tried aux cord
When playing music only one side works but when I turn it on and off it works both sides. I tried aux cord having it stay plugged in a wall. Also tried it with 2 different phones IPhone SE and Galaxy S7
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Could be that one of the channels in the amplifier is dead, or one of the speakers has blown out due to excessive volume (those tiny speakers sure do push a lot of sound).
To check and see whether this has happened, just follow the beginning part of this video on how to remove the casing. Then you can visually inspect the speakers for damage, and also check them with a multimeter.
By playing music through the speaker, you should be able to see which of the speakers isn’t working. Then you can disconnect and pull the speaker out and check the resistance with a multimeter set to the 200Ω or continuity setting. It should show a value around 4-8Ω if the speaker is good, 0 of it’s shorted internally, and and an “open circuit”, “1” or whatever it normally shows when you don’t touch the leads to each other.
If the resistance is in the 4-8Ω range, that means there’s something wrong electrically with the control board. Most likely a dead amplifier channel, since you said it happened even with an aux cord.
这个答案有帮助吗?
得分 0
3条评论:
It’s not dead I have two that I bought 2 days ago when I turn it on both the speakers work when I pair, connect, and turns off it only does not work when I play music
完成的
If you want to talk to me easier my Instagram is LookingLikeCaleb
完成的
Do you mean that you're trying to use both speakers together at the same time?
I'm confused by the issue with them, since it sounds like they turn on, but do/don't play music?
Also, I don't have an Instagram account, so the iFixit forum is easier for me.
完成的
添加一条评论
Im having the same issue. I have a 2020 ford fusion. Both of my speakers work and it just today. Should I replace the aux card too see if that helps?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Caleb Boi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 18
总计 12,069
