Switch on my tablet needs replacing
My on switch on my note pro is faulty . How can i replace it without loosing my photos and data downloads ?
the tablet is going perfect,but the switch seems to be broken or just worn ?
Hi Joe,
I would advise that you backup your device before making any repair effort.
Enabled when a check mark is present.
If disabled, existing backups are deleted from Google's servers.
Back up my data must be enabled.
This will ensure you don’t lose any data.
As far as replacing the switch, this is the part you will need:
[关联产品丢失或禁用: IF331-000]
The volume button board contains the board for the power button as well. You won’t nee to replace the physical button you see on the outside, the problem would be in the circuitry beneath.
HOWEVER, you did not include your device model information. Please ensure this part is compatible with your device.
Thanks
Ryker
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 189
