swiping up from bottom does not work on the ipad 2 front panel.
I replaced my ipad 2 front panel. everything is working except when i try to swipe up from the bottom It does not respond. I can swipe up in the middle and upper part of the ipad. but i cannot swipe upward from the very bottom of the screen. I also did not seal the ipad securely so it is partially sealed and partially not sealed towards the bottom and the left side. Could that be the problem? If not what could be the cause of the issue. I bought the screen off of ebay.
Why did you replace your original front panel? Was it broken? If it’s not broken, try reinstalling the original front panel and see if this continues.
由 Aaron Cooke 完成的
It was severely cracked to the point where it would not respond to touch.
由 Kevin Greaves 完成的
@kgreaves Alright, I suggest you take a look at Minho's answer as it answered this question well.
由 Aaron Cooke 完成的
