跳转到主内容
加入维修社区 - 创建账户
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Left Shift button not working
Hi, I have problem with my left Shift button, It works only serval times, and then stops to work, after a while it works again, what it can be ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I would pop the key cap off and see if there’s anything hiding under the key that could be preventing the key from being depressed and recognized by the logic board.
Next steps are
  1. Re-install macOS
  2. SMC and PRAM resets
  3. New keyboard
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I recently repaired a 13” 2013 Macbook Air with the left-side shift, control, and option keys not working. I tried everything software related in addition to replacing the keyboard, and the keyboard -> trackpad ribbon. In the end the very last thing I did, which was to replace the trackpad, did the trick. Comparing the two trackpads I could clearly see that the connectors on the old trackpad had shoddy damaged pins, and the single pin that handled those three keys was damaged.
这个答案有帮助吗?
得分 3
添加一条评论
you could have something stuck in your keyboard if something is stuck you must replace your keyboard
这个答案有帮助吗?
得分 0
3条评论:
If one of buttons are not working properly i need to change all keyboard ?? sounds dumb
完成的
or you could buy a new laptop
完成的
@stevejobs99 Don’t be rude.
完成的
添加一条评论
添加你的答案
garbulis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 6,916
