跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
Front Glass Not Staying
I followed all your directions which were "great" and got the itouch working. My only problem now is that I can't get the glass to click in or stay on. It appears that after I get one side in and try the other, that pushes that side back out. Can you offer any ffedback or suggestions on how i can resolve this and get the glass to stay on please? Thank you in advance, Ken
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I don't understand if you changed your digitizer? Did you move over the small metal hinge at the top of the old screen? That hooks in on the top. At the bottom (home button) you need a small adhesive like the one for iPhone 3G or 3GS. The screen should also snap into place on each side.
这个答案有帮助吗?
得分 0
2条评论:
完成的
I think I know what you mean because I had the same problem today. Make sure the cable to the digitizer (the long thin one) is tucked underneath the top of the screen. If it folds out towards the bottom it will make the screen wiggle since it is like a spacer on the edge of the top part where the camera is. Hope you get what I mean.
完成的
添加一条评论
添加你的答案
Ken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 663
