跳转到主内容
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 个问题 查看全部
How to replace drive belt
I have a 2002 Murray 11 HP 30” riding mower, model 31602A. The drive belt is frayed and slipping. I have a replacement belt, but cannot see how the belt can be installed. I removed the cutting deck and can loop the new belt over the blade pulley and onto the drive pulley, and feed the belt over all linkage, but cannot see how to install onto the rear pulley. Any suggestions would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
There should be an adjustable pulley. Or a tensioner pulley. It will have a square hole in the middle for a ratchet to insert and move it enough for you to loosen the tension on the belt and finish installing
Update (11/03/2018)
I know you have a different model then what the video is but I hope it helps
https://youtu.be/u1o9WQqOSvw
https://youtu.be/HKI7qI7iIBE
https://youtu.be/dW8DYMCjC9E
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the response, but the idler is not a problem. The shift lever connects to a shaft that goes into the gear box in front of the rear drive pulley. I don't see how to get around this.
完成的
Bring it to the shop
完成的
添加一条评论
添加你的答案
Misco 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 41
过去 30 天: 163
总计 6,803
