跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 个问题 查看全部
Which wifi card to upgrade to? Latest card that fits 2013 MacBook Pro
Would the wifi card model BCM94360CS fit the early 2013 macbook pro retina 15” ?
I want to upgrade my old wifi card that doesn’t support 802.11 ac and was wondering which is the latest model that supports it ? I am guessing the newer touchbar based macbooks have a different card ? would any of those cards support the early 2013 macbook pro ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
The newer MacBook Pro touch bar as well as the function key models all use chips which are soldered to the logic board unlike your MacBook Pro system which uses an AirPort board MacBook Pro 13" and 15" Retina (Late 2012-Early 2013) Airport/Bluetooth Board. The best you can go with is MacBook Pro Retina (2015) Airport/Bluetooth Board
MacBook Pro 13" and 15" Retina (Late 2012-Early 2013) Airport/Bluetooth Board图片
产品
$49.99
MacBook Pro Retina (2015) Airport/Bluetooth Board图片
产品
$24.99
这个答案有帮助吗?
得分 3
2条评论:
I have upgraded my 2012 MBP’s AirPort Card from 2012 to a 2015 Card. I have gig speed internet and it gets more MBPS then it’s original card. Definitely worth an upgrade if you have speedy internet.
完成的
Just did this upgrade, my download speed has 111Mbps before and now is 221Mbps. I have 300Mbps connection, but this was an amazing upgrade. Installed, didn't need to configure anything at all. Airdrop worked right away. Thank you danj.
完成的
添加一条评论
添加你的答案
scorpion789 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 23
过去 30 天: 72
总计 8,058
