跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Home button not functioning after a battery replacement
Following the iFixit battery replacement guide, I did a battery replacement a few months ago. After the battery replacement, my home button stopped working. It doesn’t register any presses and neither does Touch ID work.
My friend was doing a screen replacement on his 6S and it came with a home button. He intended on keeping his original home button, so I had asked if I could have his spare home button. However, when I installed the home button, it still did not work.
Now here’s where I think I went wrong. In the iFixit battery replacement guide, you are asked to separate the display assembly from the rest of the phone. While this step is not necessary, it would make life much easier when working on the rest of the phone.
There are 3 cables connecting the display assembly to the phone: the front camera cable, the digitizer cable, and the display cable.
I’m not sure which of these cables register home button presses, but I think I may have damaged that cable. Anyone have any other opinions as to what could be causing my home button to stop working after a battery replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would suggest going back and opening up the phone checking all the connections and check all of the pins were put back right and that they are not bent.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melophile 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 57
