跳转到主内容
苹果的iPod Touch第六代于2015年7月发布。
149 个问题 查看全部
Charges fast and dies fast
Hey I have a iPod touch 6th gen come in for repair
anyways, this is the third one that came in wasn’t charging or turning on… so I decided to change the battery and re solder a new one in. It’ll charge very quickly and drain fast as well. I’m not sure if it’s the batteries I am getting off eBay or if something hardware is at fault on the logic board causing this issue. Is this a U2 IC Failure? Any shops that have this same problem it would be great if you could chime in with a Solution. It also recognizes with the computer and charges at 0.72 volts
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Try the battery that iFixit sells.
iPod touch (6th and 7th Gen) Battery
iFixit generally has decent quality batteries.
iPod touch (6th and 7th Gen) Battery图片
产品
$19.99
这个答案有帮助吗?
得分 0
添加一条评论
ipods generally have a terrible battery life,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Ringuette 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 11
总计 2,430
