跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
203 个问题 查看全部
How to reset SMC on the 2018 MBP?
Instructions given on apple website at the link for T2 equipped devices are simply not working
https://support.apple.com/en-us/HT201295
The device simply boots up on attempting any of the 2 given combinations.
Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can you explain what you are trying to reset. The more detail the better.
完成的
添加一条评论
4个答案
最有帮助的答案
Here’s a guide on how to reset the SMC and the PRAM on your MBP. Hopefully it will work for you. If not, maybe @danj can assist you better if you provide more detail.
如何重置MacBook Pro Touch Bar 2018的SMC,PRAM和NVRAM
这个答案有帮助吗?
得分 1
2条评论:
Thank you Aaron. Yes, I attempted that, but the systems always boots up during the procedure, actually within 2-3 seconds of attempting any of the 2 alternatives
完成的
Okay, hopefully Dan will be able to help you further. Sorry about that!
完成的
添加一条评论
Press Shift + control + option button with power at the same time and release after 60 seconds altogether and continuously watch the light on the magsafe it will change color of led for a short duration of time indicates SMC reset has been successfully done
这个答案有帮助吗?
得分 0
11条评论:
Hello, and thank you for the kind reply.
This may work on older models, not the new 2018 with the T2 chip.
Also, And these models do not have a MagSafe.
完成的
Is your battery detachable or not or with touch ID
完成的
Systems with a T2 chip are very different than the older systems. Some settings are just not resettable. Depending on what the issue is we may need to use a different way.
完成的
Yes, I realise that systems with T2 are different, and therefore requiring a different procedure for the reset. I followed the instructions on apple page for systems with T2, that Aaron also posted. but this is not working. the system simply boots up 2-3 seconds when attempting any of the 2 alternatives. That does not sound right
完成的
SMS - What are you trying to re-set?
完成的
显示更多的6条评论
添加一条评论
Shift+control+option with power button
这个答案有帮助吗?
得分 0
添加一条评论
Aaron, I did this but it won’t restart. It was having issues charging. It just had a blinking red dead battery in the middle of the screen even though it was plugged in. I reset the SMC... and it never turned on and now doesn’t respond at all, I don’t even have the blinking battery anymore.
这个答案有帮助吗?
得分 0
1条评论:
@bpress - You really need to create a fresh question here with all of your systems details.
完成的
添加一条评论
添加你的答案
SMS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 2,081
