跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
20 个问题 查看全部
无法开机,按下开机键后,黑屏,只有很大的风扇声。
按下开机键后,屏幕没有反应,黑屏。键盘灯不亮,背面的苹果LOGO灯不亮。
只有风扇声。
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Can you check the clock in the host? I did the same thing last time
The clock in a computer typically refers to the internal clock system that synchronizes various operations, mainly including:
  1. System Clock: This is a clock circuit on the computer's motherboard that generates a frequency signal (usually ranging from a few MHz to several GHz) to synchronize the operation of different components of the computer. For example, the CPU, memory, and other hardware devices rely on the system clock to ensure coordinated operation.
  2. Real-Time Clock (RTC): This is a separate clock chip used to keep track of the date and time, even when the computer is powered off. The RTC typically runs on a battery, so it can maintain the time accuracy even when the power is disconnected.
  3. Clock Speed: This refers to the number of instructions the computer processor (CPU) can execute per second, usually measured in hertz (Hz), such as GHz (gigahertz). It is an important metric for measuring the CPU's processing power.
The clock in a computer is crucial for ensuring that various parts of the system work in harmony. It is involved in processes like data transmission and instruction execution, with clock signals playing a role in synchronizing these activities.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mudd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 96
