跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Replacement screen doesn't work with home button cable in board
Hi
I replaced my screen and battery after water damage (moving over my old Touch ID/home button to new screen) - phone appeared dead. I then removed the home button ribbon cable connector from the board (top right of the phone where the front camera ribbon cable etc connects) and noticed the screen fire up.
Phone appears to function fine (using home button accessibility on screen without ribbon cable connected)
Could the home button be damaged and causing a short circuit? Or does it sound like I have perhaps incorrectly reinstalled the button in the new screen?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hello
on iphone 6 the touch id flex is connected to mother board using a shielding plate. When you replace the screen did you change this plate or keep the original ? This should be replaced to avoid any doubt.
In mainy case i ve seen water destroyed the touch id function but i can t remind a case where the boot was not possible.
check your bottom connexion and check with a new shielding plate
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 70
