跳转到主内容
加入维修社区 - 创建账户
The sixth generation Maxima, code-named A34, was only sold in the United States, Canada and Mexico. It was introduced in production form as a 2004 model at the 2003 North American International Auto Show.
My brake light on dash stays on
Parking brake switch, brake light on dash stays on
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
You could bring it to the nearest Mechanic shop and get it fixed there.
完成的
Had all that fixed and it’s still on
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @pissingmeoff ,
The “brake” indicator light in the dash has two functions.
It indicates that the parking brake is applied and it is also a low brake fluid level warning light.
If the light is on with the ignition on but the parking brake is released then first check the brake fluid reservoir to ensure that the brake fluid level is correct.
If it is OK then perhaps there may be a faulty sensor in the reservoir or the parking brake switch may be faulty
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert Lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 33
总计 4,020
