跳转到主内容
MacBook, MacBook Pro, 和 MacBook Air 交流电 电源适配器。
65 个问题 查看全部
60W Magsafe Charger Making Ticking Noise, Not Charging
I have a 3rd party 60W Magsafe charger that suddenly stopped charging. I tore it down, and applied a voltage to it. I hear a ticking noise, but I’m not quite sure which component could be failing. I get no output voltage on the Magsafe pins (no surprise). Any assistance would be greatly appreciated, before I desolder the board and test each component individually. Tia!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
To be honest, you are really better off getting a replacement charger than try to fix it because the quality of aftermarket ones aren't that great they burn out and cable gets worn too easily.
这个答案有帮助吗?
得分 4
1条评论:
They are also not very good or safe! Why You Shouldn't use Cheap MacBook Chargers
完成的
添加一条评论
添加你的答案
gradidgek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 933
