跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
Battery A1309 replaced but not charging properly
Hi
Got an MacBookPro 6.1 A1297 Unibody Mid 2010
old but great 17” display and it it was just pimped up with SSD .
I was lucky to get new looking “spare” battery from a friend
Replacement A1309
  • Li-polymer 7.4V 11.2Ah
  • SN: 9G925P26G4M0A (seems not a SerialNumber as other has posted same Number..)
  • Manufacture: PS -
  • Gerätename: CL5369
  • Pack Lot Code : 4215 - PCB Lot Code: 111 (according CoconutBattery thats manufactured Sept 2015.. )
But I face similar problem as reported in many forums:
„SystemInformation“ shows only 36 cycles and 8259mV and „vollständig geladen“ JA / 100%.
The „verbleibende Ladung“ 10940mA looks great but it drops after a few minutes to 7% and system shuts down.
Whats strange that “Stromverbrauch” is indicate zero, but unfortunate the data in „SystemInformation“ are not updated automatically so information might be not accurate as system only charges / run a few minutes/seconds.
After connection MagSafe the system can be restarted, MagSafe connector turns Amber and „System Information“ indicate„ Batterie wird geladen“ JA-YES, but again after a few minutes it indicates already „full“ and MagSafe turns Green
I did the what AppleSupport recommends:
  • Removed new Battery again
  • Press „Power On“ button
  • Connect Battery again
  • Shift+Ctrl+Alt + power on button for 5 sec
Problem remains : (
I doubt that there is problem with PS or Mainboard as old Battery (already disposed) was at least charging and de-charging normal.
The Battery does not looks damaged and Voltage between Pin 1-5 against 9-13 shows 8.25V and between 7-8 against 9-13 shows 7.5V.
If it would be NiCa I would say its „Memory-Effect“.
But LiPo should not have that weakness ?! Might the un-attendance in storage cause other damage? Manufacture Date Sept 2015 - only 36 cycles..
I have Early 2011 MBP 8.3 with A1383 Battery manufactured Feb 2011 with 1033 cycles and that one still runs many hours.
So what went wrong with that “Replacement” Battery?
Is it typical for LiPo to keep Voltage (no load) but not store any energy anymore?
Sure if it charges only 5 min I can’t expect that Battery is getting ever full.
I guess there is some electronic - either in system or the Battery Pack which stop charging due to 8.25 V (max Voltage LiPo cell is recommended 4.2 according wiki)
I am wondering if nobody else has any hint or explanation ?
Can I open the Battery Pack and fix something?
Full Battery 100% but its drained after 1min
with attached MagSafe its charging “amber”
but after 5min it changes to “green”
How can I get the “Voltage” down which probably stops the charging?
Regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Lets see if we can get some deeper diagnostics here. Install this gem of a app CoconutBattery it will allow you to see your batteries status as well as its wear. It will also let you see more clearly what the MagSafe charger is doing and what the systems logic is doing to damage the battery. Lets get a snapshot of the original battery with the MagSafe connected and then do your friends battery and paste them here for us to see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
3条评论:
Here’s a guide for coconutBattery, if needed.
How to Test a Mac Laptop Battery
完成的
Thanks for answer and CoconutBattery is a nice small program, but it does not tell me more that what I already looked up in SystemProfile-Device..
Before I blame Manufacture PS I like to understand setup.
完成的
It allows us to see whats happening. The discharge rate is very high! So you have a short. Is your system warm to the touch?
Did you get your system wet at some point? Ether a liquid spill or sit it down on a wet surface.
完成的
添加一条评论
添加你的答案
Edi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 407
