跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
After market battery replacement.
What are people’s experience with aftermarket batteries in older mac laptops? I had a machine miraculously come back to life after 2 years of being bricked and stored in a cupboard. Everything seems to work properly but the battery doesn’t hold a charge particularly well. I’d like to understand the potential problems that apple soft/firmware might have with after market/compatible batteries.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have an aftermarket battery in my original C2D MacBook Air and it works great. The battery lasts up to 4-6 hours depending on use and there are no issues with the OS. That being said the max OS you can get on that particular MBA is OS X 10.7.5 and I cannot really relate to using an aftermarket battery on a (somewhat) newer MBA that can keep up to Mojave.
I think you will have zero issues with a new battery, so I highly advise you to make that purchase.
MacBook Air 13" 2012 中期 电池更换
MacBook Air 13" (Late 2010-2017) Battery
MacBook Air 13" (Late 2010-2017) Battery图片
产品
$69.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 50
