跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Backlight In And Out Voltage
Hi everyone.. And @refectio :)
I have a question plz , related Schematic.
Someone tell me plz how can i know input and output voltage.
In the image , we have U1502, I think input is vccmain right?
Is input voltage always in the left and output in the right???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi AGS. A well drawn schematic should follow certain conventions to make reading them easier. In general, the iPhone schematics are very good and easy to read whereas some of the Android device schematics I have seen can be a bit confusing.
Input voltage is usually on the top or top right of the schematic. Other signal inputs are also usually on the left. All outputs should be on the right. Power rails are usually thicker lines whereas digital signals have a thin line. This is well respected in the snippet you have attached to your question. Overall, the flow should be left to right and not vertical and everything should be broken out within functional blocks with easy to understand netnames.
There is a lot good information here if you want to read through it. Also, the EEVBlog recently put out a video to address this, it’s an interesting watch.
这个答案有帮助吗?
得分 1
1条评论:
Thanks a lot @refectio SIR ... you are my ideal :))))
完成的
添加一条评论
添加你的答案
AGS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 315
