跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Strange things happening after screen replacement
I have replaced the screen on an iPhone7 Plus. Everything worked before. Now it has a long boot time and the volume controls, vibrator, sound, microphone, speaker front facing camera, home button all do not work, but the slide button for mute does work. I have tried it changed it back to the old screen and still does not work. Switched back to the new screen and of course does not work. I decided to unplug the top flex cable that has the camera prox sensor and ear speaker on it, now it the volume controls, sound and voice works. This is a new flex cable for the camera and prox sensor. Also the boot time is normal. If I plug it back in then everything goes back to not working again. Any ideas on this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Why the duplicate question?
完成的
@minho after I posted this I realized I should have just updated the old post. It was a long day. But with what you said in the last post, I think this changes the out look on what is going on. Do you have any other ideas?
完成的
添加一条评论
2个答案
已选择的解决方案
If things work without the FCAM flex and they don't when plugged in it sounds like a bad FCAM flex.
FWIW…my username is @refectio, not @minho
这个答案有帮助吗?
得分 1
5条评论:
I will be looking into having the Flax cable exchanged out then.
完成的
@refectio I purchased a new screen that came with the flex cable installed. Again Still having the same problem. One thing did change, now the home button is working.
完成的
I would never trust a flex that is pre-installed in a screen, they tend to put lower quality flexes. Did anything work from the flex (FCAM, ALS, Prox, Speaker) or is nothing working?
完成的
When I plug in the flex cable it has a long load time and nothing works, not even the home button. This is now the 2nd screen and 2nd flex cable. Other than the flex cable on this one was preinstalled.
完成的
While I don't trust pre-installed flexes, the fact that you have two with the exact same problem tends to point to a logic board issue. I would carefully inspect the FCAM connector on the logic board and it's surrounding area for any signs of damage. At this point, the board needs to be probed to get a better understanding.
完成的
添加一条评论
最有帮助的答案
Whoever replaced your screen:
  1. Wasnt wearing the proper equipment (static band so that the delicate electronics wont be destroyed)
  2. Replaced it incorrectly so that some components are failing.
  3. Unfortunately at this point there is nothing that can be done. Over time more and more of the device will deteriorate and stop working. You need to 1. get a new phone. 2. Write a bad review for whoever replaced it. 3. Complain to whoever fixed your screen, they are unproffesional and not good at their job.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Brent Norris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 80
