跳转到主内容
The Bose QuietComfort 20i are in-ear headphones from Bose. Released in August of 2013. Model number: 362544-0010.
12 个问题 查看全部
Earphone cracked open, noise cancelling makes high pitch sound now.
Need to find a way to fix the earphone noise cancelling function so it doesnt sound like a high pitch sound.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
I tried this and mine are now working perfectly again
https://www.youtube.com/watch?v=JPp12Cnx...
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem today. I pulled the ear bud apart further to see if there was any exposed wires or other metal parts touching. I’m not sure if just moving it around caused the squealing to stop, but I then held it tightly together to see if in the position everything was in would cause the squealing. Once I verified that it would not I filled the cracks in with super glue and let it dry (10-15 sec). Seems to be working normally now.
这个答案有帮助吗?
得分 0
添加一条评论
tried isolating cables with no improvement
这个答案有帮助吗?
得分 0
添加一条评论
The air leak in the ear chamber creates this problem. Seal casing with a silicone glue. While in cancellation noise mode, block the ear bud. It will make a shrilling sound. With your other hand, sandwich the casing. The sound will disappear because your ear chamber is air tight.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Miguel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 22
总计 1,962
