Nothing working after battery replacement. Help!
HELP!
Just did the full battery replacement sequence and got 2 start up chimes when i plugged it in and then nothing.
I took the back off again and had a really good look to make sure everything was plugged in properly .
Still nothing.
Put back together and let it charge for a while.
Still nothing . It’s warm to touch at the center rear, but the battery area isn’t warm.
The charger is showing green, suggesting battery is charged.
Took the back off again and unplugged battery and keyboard and replugged.
Plugged back into the power with back off and the fans came on for about a min before turning off.
So not sure where to go from here.
I replaced the battery because it was going flat too soon and i was getting a replace battery soon message. No other issues.
Any help is greatly appreciated.
Cheers Tim
try to perform soft reset while removing battery and charging cable press power button for around 60 seconds and after that insert the battery and try to restart the Mac
由 Amily Grey 完成的
